  1. I'm getting a sound error when I use DVDToolbox. It states: "audio bitrate search did not find all needed bitrates. Estimates may not be correct." Here are my steps.
    1. Ripp w/ DVD Decrypter in file mode and select all files
    2. Load those files into DVDtoolbox, select strip/split, thats when i get the error
    3. select the video stream i want, delect the audio and sub streams from the video that I don't want
    I was just wondering if I am doing something wrong or if DVDToolbox may be having troubles w/ the DTS sound stream. I am having the troubles on Harry Potter and Sweet home alabama. Thanks in advance!
  2. @Joeman81
    As mentioned by the message the only thing that is wrong after
    this message is the estimations may be wrong !
    (so, don't panic !)
    Are you using the latest Version (0.06.0a) ?
