  1. Hi Major,
    I have some Mov movies! "DV PAL" I whant to convert it to SVCD PAL. I tried to convert it to a SVCD I but only Got a m2v and mp 2 file, not the 2 img. files? I haven use FFMPEGX for while, mybe i am doing something wrong?
    FFMPEGX 0.0.6g
    Terminal windows says:
    Stream #0.0 -> #0.0
    Press [q] to stop encoding
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    YUV4MPEG stream header written. FPS is 25
    ++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
    ++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
    Error while decoding stream #0.0B time=0.8 bitrate=82945.7kbits/s
    Abourt 100 of those lines......
    Error while decoding stream #0.0B time=222.6 bitrate=82945.4kbits/s
    Error while decoding stream #0.0B time=223.4 bitrate=82945.4kbits/s
    frame= 5587 q=0.0 size= 2262773kB time=223.5 bitrate=82945.4kbits/s
    Input #0, mov, from '/Volumes/TEST Backup/806 Film/806_1':
    Stream #0.0: Video: dvvideo, 720x576, 14.12 fps, 800 kb/s
    Stream #0.1: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Output #0, mp2, to '/Users/admin/Desktop/tyst/fhff.mp2':
    Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Warning, allocating 0 bytes
    sh: line 1: 594 Segmentation fault /Applications/FFMPEGX/ffmpegX.app//Contents/Resources/ffmpeg -i /Volumes/TEST\ Backup/Peugeot\ 806\ Film/Peugeot\ 806_1 -y -vn -f mp2 -acodec mp2 -ab 224 -ar 44100 -ac 2 -map 1.1:0.0 /Users/admin/Desktop/tyst/fhff.mp2
    INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
    INFO: [mplex] File /Users/admin/Desktop/tyst/fhff.m2v looks like an MPEG Video stream.
    **ERROR: [mplex] Unable to read from file /Users/admin/Desktop/tyst/fhff.mp2.
    /Users/admin/Desktop/tyst/fhff.mpg is not a valid mpeg file
    (Super) VideoCD xml description created successfully as `/Users/admin/Desktop/tyst/fhff.xml'
    ++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
    ++ WARN:
    ++ WARN: this is the UNSTABLE development branch!
    ++ WARN: use only if you know what you are doing
    ++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    ++ WARN:
    **ERROR: could not stat() file `/Users/admin/Desktop/tyst/fhff.mpg.mpg': No such file or directory
    rm: /Users/admin/Desktop/tyst/fhff_02_pregap.img: No such file or directory
    rm: /Users/admin/Desktop/tyst/fhff: No such file or directory
    Encoding completed on Sun Mar 2 22:36:33 CET 2003
    Please Help
    Editor
  2. Make sure your source filename ends with ".mov"
  3. Thanks Major,
    I forgot i!!!
    But now i get 3 files a m2v, mp2 and a mpeg file, I still donīt get the 2 img. files? hmmmm.
    I says in terminal window if I will overright the mpeg file (n,y,a) I says n but I still donīt get the 2 img files
    Mybe i have been away to long from my Mac!
    Regards
    Editor
  4. Hi Editer,
    maybe you forgot to tick "postprocess split and author" ?
    This is the step where the mpeg file is split and converted to .img files.
    Or simply this postprocess could not occur because the terminal was waiting an answer from you, if you would like to overwrite the files which already existed on your HD... (I mean you did not delete them from your previous attempt to encode)
    Anyway, now that you have the mpeg file, you still can postprocess it either with ffmpeg (go into the tools tab, choose video as your mpeg file, no need to choose the sound file, just tick postprocess split and author, keep elementary streams, split in 2 or 3, author as SVCD and then "go") or you can split the file with mpgtxwrap and author it with VCDbuilder...
    Hope this helps.
