hey,
im having truble capturing avi with my pctv pro.
it drops 24 frames a minute !!!.
the truble is that it only hapens with winxp, if i use my win98
i dont have that problem at all.
i have tried capturing with lower resolution and lower audio qulity
but it doesnt work no metter what settings i use.
its the first time im having this kind of problem, i even installed
windows again but it didnt work...
it allways dropes 24 - 25 frames a minute.
i hope you can help
Amd 2000+
128 mb ddr
video compression - mjpg codec
audio compression - cd qulity 172 kb
resolution - 640 X 576 (and then downsizing for svcd or cvd)
HELL AINT A BAD PLACE TO BE
Your configuration shouldn't give dropped frames. Since it doesn't in Win98, I would first suspect the WinXP drivers. Search for newer.
Also, if your card and drivers suport it, capture through the WDM drivers, not the Video for Windows drivers. The WDM are newer and much faster.
Also, I would capture at the final resolution to be used in SVCD or VCD. Saves bandwidth and time to resize.The more I learn, the more I come to realize how little it is I know. -
thanks for the reply SaSi.
i figured out what it was that gave me the problem.
i have an onboard ac97 codec, and it seems that it is causing the
problems on windows xp.
i just installed my old creative audio card, and it works grate
NO droped frames at all.
im going to stick with my old creative vibra, it never failed me..
thanks for the help though
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 09:53 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 09:41 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
