  1. Damn !!.. instaled yesterday Dvd2Dvdr 1.3.8 since then 4 movies that I made when I go to burn with Nero 5.5.10.7 gives me a files alocation error / the dvd might be unplayable (something like that).
    With the same Nero version never gave me that error before and DOES NOT give that error with movies made before I instaled Dvd2Dvdr 1.3.8 !! (Before i used Dvd2Dvdr 1.3.4 stil instaled )
    Is the problem in Nero ? Dvd2Dvdr 1.3.8 ? .. and if i burn the disc anyway wil I have problems ?? ( just burned -rw and it seems fine )
    some reply would be apreciated... thanks
  2. Thank you all for the reply !
    I now checked and confirmed that it only hapends with Dvd2dvdr 1.3.8 with the older version does not give any error !
    ... so.. the problem is in Dvd2dvdr not in Nero.
  3. Yes Nero solved burning issues and compatibility issues in latest release. SO I would have to say it's DVD2DVDR..
