I have downloaded a small movie clip and i have been trying to converted to vcd using nero sofoware. However when i try to load it into nero window area after opening nero vcd compilation wizard, the clip (file) would not transfer into nero's window enviroment-[i don't know how to explain it-anybody got my point please?] Anyway whenever i try to transfe the clip into nero conversion window, it would automaticlly closes the nero enviroment completly and i am back to my desktop enviroment. I tried in many occasions. I don't have a problem with other movie files/clips. I have all latest codecs and softwares. I tried to reencod it using TPMPGE File encoder and it would not let me do it. I get an error that would say "CAN NOT BE USED AS EXTERNAL ENCODER". Is is weired i have not even tried to use as an external encoder rather i was just want to reincode it to mpeg file format so i can converted it into VCD using nero software. I don't know what i am doing wrong and I don't know what is going on. Can anyone please have any suggestion or help me rectify this problem? Thanks and appreciate your help. Just in case, the following is information regarding this particular movie file clip.
File : 59 Mb (57 Mb), duration 0:05:54, type MPG, 1 audio stream(s), quality 77 %
Video : 48 Mb, 1150 Kbps, 29.970 fps, res. 352*240 (4:3), MPG1 = MPEG 1 (VCD), supported
Audio : 9 Mb, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], supported
Results 1 to 1 of 1
Difference between encoding and converting video
By nb23 in forum Newbie / General discussionsReplies: 6Last Post: 21st Sep 2009, 00:13 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
