hello..ive a 748m/b mpeg file and would like to put it on 2 discs as my burner won't overburn.
.is it possible to do this>>??.if so would some kind expert please advise me
..many thanks for any help supplied..
keep safe/happy..a day without a smile is a day lost..
bigwardo![]()
keep safe/happy........a day without a smile is a day lost:-))
What are you burning the MPEG file as?
If you are burning as either a VCD or SVCD then this will fit on an 80min (700mb) CD - in these formats you can get up to 800mb+ on the CD, but if you are only using 74min CDs then yes you need to split it as the most you can fit (without overburn) is 740mb.
If you are just copying the file to CD as data then you can only fit 700mb on the 80min and 650mb on the 74min disk.
If you still need to split the file then you can use the 'MPEG TOOLS' in TMPGEnc to cut the file into 2.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Dividing a large file into chapters how?
By ZedFighter in forum EditingReplies: 0Last Post: 5th Sep 2008, 16:00 -
Dividing an AVI into smaller files
By hygieneboy in forum EditingReplies: 15Last Post: 25th Apr 2008, 16:31
