  1. Hiya
    I have a MPEG Writer/Converter (free version), and there a few things on it i dont really understand.
    I put in my SOURCE file, and file target option.
    Then underneath there are 'MPEG Output Options':-
    The Format is set to - Standard MPEG-1 (which I assume is correct, as I cant change it)
    Autosize - Is checked
    PAL - Is checked
    Frame Rate - Now this varies from 7 - 60 I am unsure of what frame rate i need to use
    Bit Rate - This again varies from 1000-4000 - any ideas which direction I need to go for this one?
    Width & Height are both set @ 'Original' - can anyone tell me what this is the measurements OF? and how do I know which i need to use.
    If anyone has any help they can offer me, It would be much appreciated!
    Thanx to anyone
  2. Oh another thing is :
    Some avi's I put in to convert comes up with :-
    Unable to load source file. The stream my be corrupt or the data type is unsupported
    Why are these SO different to the ones that work?
    Thanx Dy
