I have an 83 mb MPEG file that lasts 8 minutes when I open it in VirtualDub. If I play the file in any other player, like WMP, WinDVD, it only plays the first minute of the movie, and after 1 minute, the video stops, but the audio just continues (in WMP). I tried demultiplexing, but when I did that, I only got a 8 mb M1V. I tried editing and saving it again with TMPGENCs mpeg editor, didn't work either. I had this problem before, I fixed it, but I can't remember how I did that. My quess would be with TMPGENC's mpeg editor, but this time it doesnt work with that either.
I also tried MPEG corrector, but that doesnt fix it either.
Anyone got any ideas?
Save it as an AVI in VirtualDub, you can then re-encode it if you so need.
That doesnt work, when I select Direct Stream Copy, and try to saveit as an avi file, it gives me an error message:Originally Posted by crazeplaya
"The source video stream uses a compression algorithm which is not compatible with AVI files. Direct stream copy cannot be used with this stream.
Can I reencode it, and with what codec/settings for the least quality loss? -
Choose the option to save as an uncompressed AVI and choose full processing mode. This should do the trick
mp3 plays on Windows Media Player but won't play last minute in Sound Forge
By wetcamelfood in forum AudioReplies: 2Last Post: 1st Dec 2010, 15:47 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 18:47 -
1080i to 720rips.....file size per minute question.
By OrangeTTT in forum Video ConversionReplies: 13Last Post: 30th Jul 2008, 00:18 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 17:50 -
automatically cutting a large wav file into x minute chunks?
By graysky in forum AudioReplies: 5Last Post: 22nd Sep 2007, 22:12
