doe any body now why when u follow the steps using Tmpgnec and when u select to run it comes up as that it cannot create file ?
is there something u need to do before hand in order to make it work.
About the only reason I can think of for any application to do this is that you are trying to write to a non-existent drive and/or directory. Make sure the path for the output file is valid. Unlike some apps, Tmpgenc does not create missing directories.
does this mean that even if it shows the file that u are selecting is there and in the tpng program u slect for it to run and it says cannot create.i'm not sure why when the file is there (svcd) format mpeg and it doen't want to create the file.
Possible to create a 16:9 HUFFYuv file?
By brassplyer in forum Video ConversionReplies: 5Last Post: 25th May 2011, 18:11 -
How can i create this file?
By pokerpoker in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2010, 11:00 -
How to create subtitle file from transcript text file
By amagrace in forum SubtitleReplies: 7Last Post: 8th May 2008, 11:44 -
How to create a recovery file ?
By cd090580 in forum ComputerReplies: 2Last Post: 1st Apr 2008, 12:05 -
How do I create a flash file?
By kyle88 in forum MacReplies: 2Last Post: 22nd Dec 2007, 14:35
