I'm trying to make an MPEG file from an RM file, but after conversion
the sound is WAY out of sync!!
I used EOvideo for the conversion.
Does anyone have tips to do this the correct way?
Thanks,
Freddie
First things first - if at all possible, contact the person/website you got the .rm from and try and get it in a different format (divx is prob the best) - realmedia video is just plain anoying, (and usually crappy quality - just my opinion).
failing that, try one of the rm to avi guides that use a screen capture program, the fps might not be that great, but its quicker (eovideo took forever to convert on my athlon 2400+ xp), and i havnt had any sync probs. When you have the avi file, just use one of the billion guides to make your vcd from it. -
REal7ime converter does a good job of converting rm to avi. search for it on google.com
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 22:28 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 20:29
