I am using TMpeg to convert avi to Mpeg to then write it onto DVD. The problem I am having is that when converting the avi, it converts it into mv2 and mp2 files. Which wont work basically!! How do you convert avi to mpeg and get the right files ie vob ifo and dup.![]()
ThpGenc is an mpeg encoder. It does NOT produce files ready for burning to DVD. It DOES (or rtaher can) produce mpeg files that are compliant with DVD specs and so will be accepted by DVD authoring programs. You must AUTHOR a DVD with one of these programs in order to get the vob ifo and bup files that you need to burn to DVD.
Hope this helps
What's the better way to record/convert mpeg and mp4 format?
By Mark WR in forum Video ConversionReplies: 0Last Post: 11th Aug 2008, 17:21 -
Convert MKV to MPEG-2...format questions, etc.
By pcombs in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 16:58 -
what format to re-convert avi into?
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2008, 01:23 -
How do you convert the video format from MPEG-layer 3 to MPEG4 SP?
By Conconn in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 05:32 -
Convert videos from .VOB format to MPEG?
By hawkeyed76 in forum MacReplies: 5Last Post: 10th Sep 2007, 01:10
