Hi!
I didn't know where to put this post so i put it here!
Does anyone know how to schedule an encoding run? Like if i set all the options and settings in TMPGEnc or DVD2SVCD, and then want it to start encoding at a sertain time...?
Thanks in advance![]()
You can use the Windows Scheduler to run DVD2SVCD at a specified time.
1. Set up the '.D2S' file with all your encoding settings (make sure that the 'Project Position' value is blank.
2. Create a '.BAT' file containing the following command:
(Change path and filenames to match your own).C:\program files\dvd2svcd\dvd2svcd.exe -d2s:your.d2s -run -exit
3. Create a Windows Scheduled Task to run the '.BAT' file at the required time.
You can also add '-shutdown' to the BAT file to turn the PC off when finished.
VirtualDub jobs -- how to schedule them ?
By ralf07 in forum Newbie / General discussionsReplies: 1Last Post: 5th Nov 2011, 17:27 -
Using rtmpdump to schedule record and reconnect?
By RedPenguin in forum Video Streaming DownloadingReplies: 1Last Post: 5th Jul 2011, 00:04 -
Is there a program to schedule time for playing video files
By Chewbacco in forum Software PlayingReplies: 2Last Post: 19th Dec 2009, 06:21 -
DVB-t300 schedule recording problem
By sharkbite in forum DVB / IPTVReplies: 0Last Post: 23rd Aug 2009, 19:59 -
Easier way to schedule captures
By 4evrplan in forum Capturing and VCRReplies: 6Last Post: 4th Oct 2007, 00:04
