Hey whats up? I am having a slight problem using ifoedit .95 and rempeg (ver 152).
I ripped a disc to my hardrive using smart ripper. I had to use rempeg to lower the bitrate of the extras to fit on the new disc i want to make.
The dvd has 3 titles (title 1 being the film and title 2-3 being the extras). I used ifoedit .95 and opened up the first ifo file for the extras (vts_02.ifo) and used its function to work with rempeg, which was fine.
Once regmpeg was done I opened up ifoedit again and selected the vob file ifo (for title 2) I want to remux it with . I went under vob extras and selected “remux”. On his screen I selected correct vob navigation and correct ifo files. Once done I put the new vob into the title set and then did the whole get vts sectors for all of the ifo files.
Here is my main problem. The extras ALL now work fine with the new files I made, however if I go to watch the main film (which is title set 1 (vts_01_1-4.vobs), for some odd reason it jumps to the trailer which is in the extras section it then goes to the film and even then it is very gltichy. The actual dvd does not do this. What exactly did I do wrong or what can I do to fix this problem? Thanks again--
