When ever I try to load a clip into TMPGENC, I get an error that it cannot read the clip or recognise it. From what I read in this forum it presumably has something to do with codecs. Well I checked all that and they must be installed else how can I watch everything in Mdeia Player.
Does anyone have any ideas to why this maybe happening?
BTW, the version I have is TMPGEnc Plus-2.510.49.157
Indy
System Specs:
3.0 GHz Intel, 1 Gig RAM, WinXP, 2x40 Gig HD, ATI 64Meg Radeon VIVO, Sony DRU500A DVD-R -
...and in what format(s) are your clips?
Use GSpot (see TOOLS) to identify what codecs a given file uses.
/Mats -
The best way to open all lot of different clips and see if you have the needed codecs is to open them with VirtualDub and frameserve to TMPGEnc... That's what I do for some weird DivX files....
I checked with GSpot and it says "n.a" under both Video and Audio Codec. Now how can that be if I can play the .mpg in Media Player?
I had an unfortunate incident which resulted in having to re-install XP. However, in my previous install everything was working fine.
Any ideas?Indy
System Specs:
Now we're getting somewhere! It's MPEG, you say. GSpot only handles AVI.
If it's mpeg1, then TMPGEnc ought to be able to open it. If it's mpeg2, then TMPGEnc is not able to open it as is. You must have a 3rd party mpeg2 decoder in your system. The one used in PowerDVD can also be used by TMPGEnc, so just install PowerDVD (or the trial of PowerDVD) and TMPGEnc can read mpeg2!
/Mats -
OK...here's where it begins to get interesting. I have PowerDVD Pro EX 4.0 installed but still no luck. It sounds like that maybe TMPGENC is not so compatible with this latest release of PowerDVD.
Any thoughts?Indy
System Specs:
Could be - but it ought to be mentioned somewhere.
I don't have PowerDVD at this box I'm in front of right now, but I think the mpeg2 decoder should show up under Environmental settings/VFAPI Plugin. If it's there, try to raise its priority.
/Mats -
It's in the Env. settings and I've increased it's priority to 4. Is there a max to this?
Indy
System Specs:
Scrabble game won't load
By Psco2007 in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2010, 20:41 -
convertx todvd won't load
By xbill in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2010, 15:22 -
Windows XP won't load
By Tom Saurus in forum ComputerReplies: 21Last Post: 12th Jun 2010, 10:36 -
Application won't load for all users
By mattman1968 in forum ComputerReplies: 9Last Post: 9th Nov 2007, 10:22 -
Program won't load?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Sep 2007, 03:36
