  1. when i rip a dvd ,3 or 4 files fine,but 1 or 2 of the files have either commentary,or in a different language,tried smart ripper, and clad ,same thing,.
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    I am not sure what you have done.
    First: A ripper rips all audio tracks. Did you rip the DVD Vob's at once? Did you create a WAV file with DVD2AVI? If you have created a WAV file, did you do this at once?
    The Dutchman
  3. I've got the same pb.
    I did exactly the same using smartripper setting:key check every vob file,file splitting every vob file,options:create file list,unlock drive,demacro vision,copy ifo file,create index file,create info file,vob file access normal or aspi...
    Then I use DVD2AVI which gathers all the vob files and split audio and video.
    Then I use TMPGEnc to create the VCD but I remarqued that file sound is in English...
    I'm French and I'd prefer in French.
    Don't know what's wrong.
    Please help me.
    Feb 2001
    Berlin, Germany
    Select a different audio track in dvd2avi!
    Have a look at Smartripper's INFO file to select the one you need.
  5. I had the same problem with smartripper. I went to the "Stream Processing" tab and checked "Enable Stream Processing" and checked "Video NTSC" and one of the languages.
  6. I also have this problem trying to ripp a anime movie that is in japanese with subtitles but i watched it in english without subs on the dvd player if you know how to remedy this it would be appreciated
