Is it possible to use Constant Quality as Rate control Mode for encoding my video.
Now it seems i can only use VBR and CBR.
If it is possible how should i do that?
trenchy
Well, prepare yourself for a shock. You can do CQ, issue is how:
Go to the Video Settings form (where you select CBR, VBR and bitrates), and SET AVERAGE BITRATE TO ZERO (YES, 0).
Then Click on any other field (to let Mainconcept digest this, and (MAGIC) the constant quality selector becomes enabled).
NB: I am a programmer myself and usability like this makes me ashamed of what I do and sympathetic to innocent victims of my profession
The more I learn, the more I come to realize how little it is I know.
constant buzz from earphones
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2012, 18:43 -
Can't get constant power to the motherboard
By DarrellS in forum ComputerReplies: 5Last Post: 20th Apr 2010, 21:12 -
Constant resolution in GK
By eliqush in forum EditingReplies: 0Last Post: 5th Aug 2009, 10:28 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
