A while back i had a thread about Playstation 2's. Anyways the problem is the PS2 freezes up when the dvd-r gets to the main movie. When you click PLay now on my menu, it goes through 3 trailers which are each their own title. When it gets to the main movie (Title 4 Chapter 1) it freezes. It may play a few frames, but i cannot tell since it is a still shot. I have tried both Memorex and Imation discs. Burned with the A03 drive using latest version of nero. It plays fine on other standalones and the pc. If i go to the chapter selection menu, i can play any other chapter, but if i click chapter 1 in the selection menu, it freezes just as if i clicked play now and watched the trailers.
What could be the problem?
Any help is appreciated.
Results 1 to 9 of 9
What version is ur ps2?
It sounds like your laser isnt strong enuf to read the outer edge of the disc?
I got a v7 and it plays all my ritek g03s perfect -
would that do it? the laser that is. umm i tried on a v4, 5, 6 and a 1 or 2. The v1or 2 didnt do anything just disc read error. the other three did the same thing i mentioned about where it freezes at the beginning of the movie, which is about 500 mb into the disc (4th title)
Im certain that a v7 has a stronger(calibrated different) laser than older versions but not too sure if this is the reason.
Try usin some real good media like tdk or pioneer if u can- it sounds like the prob.
What burn method are u usin?
I use dvd2one and prassi- perfect every time -
i am using tmpgenc to encode, maestro for authoring, nero for burn (latest version). Using Imation media. It works in all the standalones i have tried so far and in the pc
I runnin outta ideas here fast so my last idea isnt really a solution just an alternative. Try instant copy or dvd2one on same movie usin same media. if it dont work then ud better get ur self a standalone.
Good luck -
My PS2 is having the same problem. Maybe a firmware update will fix the problem? Or it could just be the DVD-Rs I'm using (Imation + K-Hypermedia) I'm going to try a Maxell disc as soon as a movie I'm rendering is done. I'll let you know if it makes a difference. By the way, does anyone know where I can find firmware updates for the PS2? Do any newer games or add-on hardware have newer firmware?
I doubt you can update firmware on PS2. You can update the DVD software although i doubt it changes anything. If you could update the firmware then why would anybody need a modchip? But yeah let me know how it turns out with the maxell test.
I guess one lesson learned is that PS2s are good game machines but terrible DVD players. -
Originally Posted by JamesB69
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 19:47 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 22:36 -
Capturing PS2 Footage
By -ODeN- in forum Capturing and VCRReplies: 3Last Post: 6th Jan 2009, 15:21 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 11:31
