  1. Is there anyway I can fix a GOP problem in a MPG2 without reencoding?
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    In general No is the answer. GOP structure is the result of the encoding process.
    However, if you are using an MPEG-2 file for authoring SVCD, then you should not have a GOP problem.
    What exactly are you trying to do and what is the problem?
    The more I learn, the more I come to realize how little it is I know.
  3. i'm creating a SVCD-DVD, and only one of the files has this problem, reeldvd is giving me this error:
    Error : Number of fields (40) in GOP(# 293) or between sequence_header_code should be equal or smaller than 36.
    and that's after i reencoded it with tmpgenc.
    any ideas?
    jeff
  4. Member SaSi's Avatar
    Jan 2003
    Hellas
    OK you are using SVCD material (well, almost) to author a DVD. In general it works, however your problem is that the encoding (of that file) doesn't follow the rules.
    Explaining the problem is a bit lengthy, perhaps the best thing to do is suggest a cure.
    In Tmpgenc, in Settings --> GOP Structure, select the following
    settings (for PAL video)
    1 5 2 1 15 (for progressive video). You should be fine with
    1 5 2 1 30 (for interlaced video).
