When i open the file with tmpge i use the project wizard and part 3/5 i click on source range and then it gives me an error msg of tmpgenc.exe has encountered a problem and needs to close. We are sorry for the inconvenience. I have never experienced this problem before can anybody tell me why this error comes up? THX
I don't think TMPG can read ASF files. You have to work around it with VirtualDub. The problem is there is only one version of VirtualDub can deal with ASF file. I forgot which version it was. It is hard to find.
I got virtualdub 1.3 and it did the audio but the tmpge is still not encoding the asf file.
I used ASFtools 3.1 and converted it to an AVI file. I then used Nero to convert the file and made it into a VCD but now no volume. How do i correct this? THX
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
