I just burned a vcd with nero and when I try to play it it doesn't work. For some reason my computer thinks its an audio cd. It has no directory structure, which I believe it should. This probably means nero screwed up burning it or something. What the hell is wrong!?!?
It's Good To Be The King.
When starting Nero you should determine what type of CD you are going to burn. In your case VideoCD. Drag and drop the appropriate mpeg across and burn. When finished you should have quite a few directories.
Are you sure your version of Nero burns VideoCD's?
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 08:52 -
My new capture card can record and playback, but won't live stream. :-/
By Deadlight7 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2010, 23:50 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 14:29 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25 -
Win Media Player won't playback mpeg video
By Borgatt in forum Software PlayingReplies: 5Last Post: 21st Jun 2007, 02:46
