On another topic I was advised to Frameserve my DV through VirtualDub into TMPGEnc to encode to (x)vcd rather than create a separate edited DV file. So, I downloaded VirtualDub and found that my DV files recorded through a Canopus ADVC-50 card is not readable by VirtualDub.
Can anyone pass on any information on any way round this, or while using the Canopus Codec am I not able to use VirtualDub? (I am aware I can not capture using VirtualDub while using a Canopus card)
Thanks.
Cole
I also use the Canopus ADVC-50 and Virtualdub, and it works fine. However, I always record DV type 2, and not type 1 or native Canopus format.
Sorry Skittelson, but could you enlarge on how to make the settings. Are you making these settings in VirtualDub or somewhere else?
I am also unable to open any current DV file recorded using the Canopus card in VirtualDub.Cole -
use the free canopus dv file convertor to change your already captured files ... its in the tools section i believe. you can also load the panasonic freeware dv codec to do the same thing -- unless you are using premiere , vegas or have purchased the canopus or main concept dv codec ..
otherwise do as skittelsen says .. -
Yes, to use your already captured files, you will need to convert them to Type 2. Look for a DV file converter in the Tools section on this web site.
I use ScLive capture program to capture my DV files, and select the DV type 2 format as the capture format.
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Canopus FireCoder
By Canadian* in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Nov 2007, 21:34 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
