  1. I've done everything that is said, but cant get 42 to work.
    This is what I get. It did this all last night for 9 hours.
    If some one could help that would be great.
    arri
  2. Anonymous
    Guest
    hummm, got me. Do you think you could provide us with some useful information about if you are running the current version, if you updated it from 1.0 or installed 1.5 and have done the subsequent updates or what? What type of conversion are you trying to accomplish? Oh, you read the readme right? If you installed it after you had installed 1.0 did you trash all the old 42 files? I would recommend trashing anything remotely belonging to 42 and installing from scratch 1.5 and updating to 1.5.2. Just my $.02
    A@ron
  3. I trashed anything remotely belonging to 42 and installing from scratch 1.5 and updated to 1.5.2 and all is working now.
    Thanks A@ron
  4. Anonymous
    Guest
    Glad to be of some help Now, if only I could get 42 to actually output something in the burnwhatsinhere folder I'd be one happy camper. I've found that 75% of user problems is people not trashing old 42 files prior to installation. It would be great if the installer could search for a prior installation and delete it Wow add this for 1.7.5 or whatever the next version is.
    Wish list:
    1)Batch encoding... Select multiple batch encoding and it Xfers all the movies to the HD. Prompting you to insert them one after another and then goes on encoding the whole lot while you are away for the weekend.
    2)With it creating bin/cue it would be great to select source size for VCD/SVCDs. For example, 70 min CDR, 80 min CDR, or 99 min CDR (yes they exsist)
    3)Show processes in terminal or something to that effect to aid in user problems with the program. Or maybe someone just wants to see what they heck it actually does while its working its magic
    A@ron
