I am going to start authoring my movies onto SVCD's or VCD's, but I wanted to know program is the best out there? It does not matter if it freeware or I have to pay because I saved up my money so I can buy the program.
Results 1 to 13 of 13
Best? It depends on what you want to do. I've always liked TSCV (freeware) but it's not a super user friendly program. VCDEasy is easy to use, but basic. You can author with Ulead too.
Take a look to the left under Author for more ideas. If you just want to make simple x(S)VCDs with chapter/entry points and stuff just use VCDEasy. If you want to make motion menus, have multiple audio streams, etc. It gets a little harder (TSCV or Ulead). -
I am going to use MOTION MENUES, so I guess I should use Ulead. Thanks a lot Vejita-sama. I tried using TSCV before but it never worked out; there were always some errors.
Sonic MyDVD 4 has motion menus,combine video and slideshow on one disk too.Only outputs LPCM audio though.
WinProducer3 also has motion menus and you can get a trial version here.
http://www.intervideo.com/jsp/Product_Download.jsp?p=WinProducer -
I make my motion menus in flash and export them as .avi, then i convert them to vcd mpg, I author my disc's in VCDeasy. I highly reccomend this program.
Atarian (n); One who likes Atari. -
Well remember that a motion menu is really nothing more than another MPEG with text written on it. The real 'problem' is setting up the XML structure (for VCDImager based programs). It's not actually that hard.
I don't have the link on me but go to the main VCDImager homepage and their are guides there on this.
Or just use one of the commerical programs. You can also make some basic motion menus with avisynth (see guides to left under author). -
Thanks everyone, I have decided to buy Ulead software, although I still have to save another $50 (hehe!).
One more thing, do I buy Ulead DVD Workshop or Ulead DVD MovieFactory? -
Originally Posted by ATARIAN
I currently use and test ARANYM. What do you have?
Lannie
PS 520 and 1040 & 800XL still in the attic. -
Originally Posted by biney59
Can you make MOTION menus with MovieFactory? If not then I will get Workshop.
authoring software
By anasa in forum Authoring (DVD)Replies: 4Last Post: 31st May 2011, 19:19 -
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
Need fast authoring software...
By snafubaby in forum Authoring (DVD)Replies: 4Last Post: 15th Feb 2010, 03:14 -
authoring software.
By Kibble in forum Authoring (DVD)Replies: 1Last Post: 4th Mar 2008, 10:30 -
Help on what authoring software to use
By neosatusneu in forum Authoring (DVD)Replies: 5Last Post: 6th Jun 2007, 18:57
