I purchased a new NEC ND1000A OEM for £138 at Novatech last week.
Software supplied was VOBInstant DVD/DVD.
Problem is :-
I can produce DVD's using Pinnacle Expression or VOB Instant video which play fine on my standalone player using DVD+RW (Packard bell).
However, when placing the disc in the PC and Right clicking the drive in My computer, and selecting properties, the disc is identified as CD rom non writable, with various used space reports depending on the time of day!
Also, sometimes the disc appears empty in the files window, whilst other times you can see the video_ts folder and its contents.
IF I try to format using instant write format, it fails "An error occurred while formatting the medium"
Despite all this, If I produce another DVD in express or Instant video, it gets on with it and produces working DVd's, overwriting the old material with the new material on the same disc.
My trial version of Dazzle's DVD complete also refuses to recognise the drive.
The writer did not come with a driver and windows has recognised as CDrom. I have searched the net for a driver (Including NEC) but failed, so I am not sure if this is required or even part of the problem.
As the writer consistantly writes good DVD's with some SW, I assume I have some kind of configuration problem rather than a drive fault.
Any ideas greatfully received,
Results 1 to 1 of 1
Problems copying Blu-Ray disc...
By waldothewonderboy in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2012, 20:41 -
Re: dvd disc back up problems
By macca62 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2009, 11:24 -
problems with 10,000 BC DVD disc
By Gabriella555 in forum DVD RippingReplies: 2Last Post: 3rd Jul 2008, 07:35 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 01:11 -
?? Disc problems
By dazzaboy2 in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2007, 12:51
