When i run tmpgenc and try to convert any of my divx files to vcd, tryin to fit them on one cd using the guide on this site the file size is estimated to be 800megs using the wizard but comes out to around 1.5 gigs when the total conversion is done. What am i doing wrong?
what version are you using? that crap happen to me before but i when i updated tmpgenc that problem went away...
Originally Posted by scb2121
1) Encode at a lower bitrate. This will make the VCD non compliant and lower the quality. It should still play in most VCD capabale players though.
2) Split the movie across 2 (or more) disks. Use TmpGenc mpeg tools merge and split option to cut the large mpeg produced by TmpGenc in to 2 or more pieces.
autogk wrong file size and cropping
By codemaster in forum DVD RippingReplies: 5Last Post: 5th Dec 2010, 08:09 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
Wrong File Size on Ripped Files using AutoGK
By tommyjv in forum DVD RippingReplies: 4Last Post: 17th Nov 2008, 12:21 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
Why is this wmv file the wrong size?
By abisti in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 18:14
