Have made a few VCDs and SVCDs using SmartRipper and DVDx. Problem with latest one. In DVDx when Checking Standard I get the following message: VCD COMPLIANT: NO
PAL = 352x288 [Video 650-1150Kbits Audio 224Kbits] 25Hz
NTSC = 352x288 [Video 650-1150Kbits Audio 224Kbits] 25Hz 23.97.29.97Hz
Is the problem with the DVD or something else?
Joy
Joyce
VCD standard does -not- support variable bit rate, so 650-1150 bit rate will give you an error.
Thank you. My guide to DVDx says not to change the Video Bit Rate, Audio Bit Rate or Resolution. Does this mean that I can't copy this DVD?
Joyce -
any DVD can be copied, and a lot of DVD players will play discs that do not conform to the standards. check your player in the compatibility list, or try your non standard disc. if it doesn't work, rip the DVD to your hard drive, open it up in TMPGenc, and load the VCD standard template. this will ensure you have a standard disc.
Why no standard for frames per second?
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 31st Jan 2011, 04:18 -
What's the new standard?
By wild4trv30 in forum EditingReplies: 6Last Post: 31st Jan 2010, 11:39 -
Standard DVD in HD
By killerener99 in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2009, 06:14 -
Standard TV warning
By djmobius in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 24th Jul 2008, 07:10 -
Check this out!
By mikee55 in forum Off topicReplies: 6Last Post: 18th May 2007, 12:17
