Hi
I have a raher large mpeg file 2 gigs. Its an extract from a dvd and I want to be able to split it into thirds so i can author it as svcd.
I used JAW MPEG2Splitter but only the first 1/3 file works!?!?
When i go to play the 2nd or 3rd file, they dont play?
any ideas.
Is there a better program out there to split a mpeg file??
Use Gumby or ffmpegX or MoreMissingTools to split your MPEG into multiple parts.
Succes! -
in my own experience, using gumby or mma all of the parts works, but with some freezes and sometimes strange noises, generally... only the first one works ok...
dj_yerba says: legalize it!
VIVA CHILE MIERDA! -
Whee does one find gumby? Is it a Mac program or a UNIX program?
Thanks,
Allan -
Where does one find gumby? Is it a Mac program or a UNIX program?
Thanks,
Allan -
Yes, finding Gumby can be difficult. In my experience, it appears neither on Version Tracker nor in a Google search.
It is an OS X app., though I don't know if there are UNIX utilities under the hood.
You can get it at:
http://gumby.misplacedmac.com/
Regards,
Ross (no, not that Ross
mpgtx GUI mpeg editor 1.4b4
I downloaded this off versiontracker. Simple as pie. just type in how many pieces you want (i had a 2.3 gig mpeg so i split it to 3 files (793 a piece) authored these as SVCD and they play wonderfully on my player
hope this helps people
much easier than gumby and easier to find
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
TubeStick and splitting large mpegs
By benblack in forum MacReplies: 7Last Post: 30th Sep 2007, 15:11 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 19:18 -
How to get 14GB large mpeg-2 file to DVD?
By Bellman in forum Video ConversionReplies: 11Last Post: 20th May 2007, 20:38
