How do i use ac3fix?
It is a command line program. open a command window (dos box) and at the prompt type path. This will list all the directories that are saerched when you try to execute a program. Place ac3fix.exe in one of those directories or in the same directory as the .ac3 file you are trying to fix. Then type "ac3fix.exe input.ac3 output.ac3", hit return and wait for it to do its stuff. output.ac3 is the fixed file and is the one you should use for whatever you want it for from now on.
Hope this helps. -
This question seems to come up a lot. Doesn't anybody remember Dos? Punk kids just don't know what it was like in the old days!
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Ahh the good old days of the command line. Remember trying to load programs from audio cassette? 8)
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 07:56 -
Aften vs Besweet vs Super vs AC3Fix vs working
By awesomer in forum AudioReplies: 2Last Post: 18th Nov 2007, 18:28
