Hi!
I'm having trouble with these.. I can't get rid of them and it matters not which de-interlacing filter I use.
Thnx to Juergen_E and Roginator for trying to help me in another thread (about deinterlacing filter..).
I tried both, setting deinterlacing filter as first and using smart-deinterlace filter.. the lines stay..
Maybe this is nothing that concerns deinterlaing?Maybe it's something special about the DivX4 codec?Artifacts..
I dunno..
Anyone having the same problem?
If there's a solution out there, then PLEEEASE tell methnx a lot!
I had the funky horizontal lines problem as well. It's because I had the deinterlace check box checked in the Divx4 options. Fix: Don't check that box.
Yeah!! Thnx a lot
They're gone now.. but that's also mentioned in the helg files that come along with DivX4.xx
Shit that we (I) didn't read that first!
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 15:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 10:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 10:23 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 19:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 12:06
