I have a movie with AC3 audio. Following a guide I use virtual dub to direct stream the audio as a wav file, however when i try to rename it as .ac3 it has no affect, it does change the name but not the format so headac3he and ac3tool dont recognise it. What do i do?
you need to 'fix' the file with ac3fix.exe. This is a command line tool. It should be in the tools section.Originally Posted by DJMYERS
Hope this helps. -
simplest way. Download ac3fix.exe and put it in the same directory as your ac3 file. Open a command window and cahnge directory to where the ac3 file and ac3fix.exe are stored. type the following command:
ac3fix.exe myinputfile.ac3 myoutputfile.ac3.
ac3fix will run and fix any errors in your input, producing a new file called myoutputfile.ac3. Headac3he should now recognise it as ac3, assuming you are right and it is ac3 audio in the first place.
Problems importing ac3 in Vegas Pro
By mltwitz in forum AudioReplies: 0Last Post: 12th Jun 2010, 12:55 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 02:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 17:33 -
AC3 ACM Decompressor audio problems.
By cactusjack310 in forum AudioReplies: 2Last Post: 16th Dec 2007, 13:13
