Im not sure if this is a capture or a conversion issue, but since I dont have this problem with tmpeg i guess it should go here...
I used iuVCR 4.7.1.283 to capture a movie from VHS with the fps set as 25, but the info tab shows Average fps varying from 23 to 24.99 during capture.
When I try to load the finished capture into CCEsp 2.66.01.07 it tells me:
Framerate 10000000/387942 is not supported. Supported frame rate are 23.976, 24, 25, 29.97, 30, 50, 59.94 and 60.
Can i simply not use iuVCR to capture if i want to use CCE to encode? I dont have any problem loading the same file into tmpeg but cce wont accept it for some reason. Is it just pickier about what it will accept?
Results 1 to 1 of 1
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 01:20 -
xvid4psp 5.0.37 sync issue with framerate
By dafuzzbudd in forum Video ConversionReplies: 1Last Post: 2nd Mar 2010, 14:39 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
MKV framerate/Sync issue
By dragonkeeper in forum Blu-ray RippingReplies: 0Last Post: 15th May 2009, 00:14
