  1. After creating one, I can't play the damn CD on my PC although it works fine on my players. Worst part is that I can't rip out the .dat --> .mpg with VCDGear because for some reason the .dat files aren't recognised as VCD files, so the software claims. Anyone here can help me with ripping it out?
    <font size=-1>[ This Message was edited by: SonicKnight on 2001-09-08 01:04:03 ]</font>
  2. Nero...
    Did you create your VCD with a menu? Nero 5.5 still menus are not authored correctly and do not work on some stand-alone players and most software players.
    I'm not sure why VCDGear isn't working for you, but you can try this:
    Use CDR-Win to extract an image of your VCD onto the HDD. Then try VCDGear on the CUE/BIN image. This should always work.
    Once you have your CUE/BIN image, you can also use VCDXRIP (a tool in VCDImager) to extract all the media files and PBC off the VCD along with an XML descriptor.
    Regards.
    Michael Tam
    w: Morsels of Evidence
