I finally saved enough for a "cheap" Plasma. I got the Akai at Costco for about $3.2K AR. I have a Sony Camcorder which will do 16:9, so that is what I will use from now on, but I would like to redo some of my current tape library in 16:9 mode too. I have used TMPEGenc to create a 720x400 MPEG2 file, but ULead MSP 6.5's DVD plugin it refusing to use it, and says to use an MPEG2 compliant source. Is there a package that will let me do very basic authoring of a 720x400 source, or am I on the wrong track completely?
The software was right: 720x400 is not DVD-compliant. I see a couple of choices:
Use MSP to overlay black bars. Unfortunately, this will mean rerendering and recompressing your entire video.
Use TMPGEnc to encode specifying "Center (keep aspect ratio)" as the "Video arrange method." This is clearly preferred, since it will save recompression of the video source.
Hope this helps. -
Originally Posted by Scheif
The reason I ask this way is, if I just do the black bars, then the images will still be stretched out because it is just basically a 4:3 with Black Bars. I will try and try and prove myself wrong, but if you have other suggestions, that would be helpful.
Thanks! -
OK, now I'm a bit confused. I had presumed that your 720x400 video had the "correct" aspect ratio -- essentially 720x480 (DV) cropped to 720x400. But, since you say they would be distorted with black bars overlaid, perhaps this is not so.
How did you produce your 720x400 video? -
Thanks everyone.
Fairuse wizard 720x400 resolution
By Castiel in forum Video ConversionReplies: 13Last Post: 16th Feb 2015, 23:41 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
Worth it to re-author SD video from miniDV source to Blu-Ray?
By jg0001 in forum Authoring (Blu-ray)Replies: 5Last Post: 27th May 2010, 12:55 -
WHat is the best way to Author a DVD from live source?
By pdailey16 in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2008, 10:56 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 13:48
