hi
I have a avi file that is ripped from a dvd. It's high quality and about 230 mb. I wanna convert it to mpeg and burn it as a vcd. I know how to do this.
but, this is the problem.
i use TMPGEnc to convert it, a 230MB AVI file will become 700MB MPG. I wanna make the MPG smaller. I know i read a tuturial somewhere, it tells me to change the bitrate. but I can't change it for a vcd file. I don't know how to do this.
I am sure this can be done. cuz i have a VCD that's like this.
someone, ripped a full dvd into 2 mpg files, each is about 450 MB. he let me download those mpg files and i burned them as vcds. The quality of my vcd is great.
I just wanna know how to convert avi to a small mpeg without losing too much quality.
thank you in advance.
Results 1 to 11 of 11
... you CAN change the bitrate... if you reconvert the AVI that is...
once you have an MPEG file, your options are limited... what i'm trying to say is that, you can't make an MPEG file smaller...Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Originally Posted by El Torro
I think you are mistaken El Torro. You CAN reduce the size of the mpeg, by lowering the bitrate, without reconverting the avi. To do this in tmpgenc, load the unlock template found in the extras folder. You can then change any settings you desire. However it will no-longer be VCD compliant, though lower bitrate VCD's (with no other changes) tend to play in most VCD compatible players. Also it will be lower quality, especially during motion scenes. -
If you're already in too deep, you can try using REMPG to resize your file...or run it through TMPGEnc again.
Sorry for the stupid question ...but where is the extras folder in Tmpgenc? Cant find it...want to try to lower the bitrate of my MPEG.
The extras folder is in "..\templates\extras" you want to use the unlock template.
1) Load the VCD (or what every template you like)
2) Load you video/audio source file/s
3) Load the unlock template
4) Click on settings - confirm that the frame rate is correct. Change the bitrate as needed (use a bitrate calculator to determine)
5) Click on advance, confirm that the resize is correct (eg. 352x240)
6) Encode MPEG
You need to double check the framerate/resolution/etc. because sometimes these will be set to whatever your source video is. -
If you're burning this as a VCD then this 700 MB file will fit on an 80 min CD-R! An 80 min. CD-R has the capacity to hold 800 MB if burned as a VCD. A VCD is burned in mode 2 and it has a higher capacity than a regular data disk. Don't resize the file if you don't have to.Originally Posted by thekid
"Art is making something out of nothing and selling it." - Frank Zappa -
Ok I have followed Vejita-sama's exact instructions....but when i get upto the point of loading the templates extra ....i cant find it. Is that in a newer version than I am using? Im using TMPGEnc Plus 2.58.44.152. thanks again.
why is it so hard for people to understand that the size of the avi DOES NOT dictate the size of the mpg?Originally Posted by thekid
Are you using the Wizard? You can't load the unlock template in the wizard. When the wizard comes up select cancel, select your files, load your initial template, load the unlock template in the extras folder, adjust your settings, start your conversion.Originally Posted by vinnyv07"Art is making something out of nothing and selling it." - Frank Zappa
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 20:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 21:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 10:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 23:16 -
Cannot convert 1 title to ipod from self-authored DVD...
By BeachNut in forum DVD RippingReplies: 2Last Post: 4th Feb 2008, 12:48
