i downloaded something that had something bundled in with it that installed a new menu bar on internet explorer and reset my homepage. i was just wondering how to get rid of it, ive already installed ad-ware 6 and that didnt get rid of it. please help me out thanks.
Got that somehow about 6 months ago, had to use XPs restore utility to nuke it, even Lops on uninstall wasn't working.
Try this out for uninstalling the toolbar ( http://lop.com/new_uninstall.exe). It's meant to be the uninstall program for the toolbar.
Hope you have better luck with it then I did, cause like I said I couldn't tell that their uninstaller did a thing.
i got that last night
i ran adaware, then went to add/remove to uninstall and i think i deleted the folder that it was in and all the other crap.
restarted
the tool bar went away,but all the text documents that i have on the desktop change to their icon.i went out and when i came back the icons changed backed to the way they were.
i dont know if its all gone,but i dont see any evidence of it.i'm way over due for a format anyway.
Help with audio in bar please
By theflame01 in forum AudioReplies: 0Last Post: 30th Apr 2010, 06:21 -
Wii Sensor Bar
By Squid_uk in forum Off topicReplies: 5Last Post: 26th Jun 2009, 21:03 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 8th Oct 2008, 00:36 -
Sony RDR-VX410 Annoying menu bar when capturing
By wozmac in forum Capturing and VCRReplies: 0Last Post: 22nd Jul 2008, 10:20 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29
