I have been experimenting with Movie Factory 2 to crreate DVDs and have mostly figured out how to do what I need to do with it. Something that I cannot figure out relates to audio during the first clip in the series if the "First clip as first play video" box is checked.
I use TMPGEnc Plus to generate all of my MPEG-2 video, with Toolame as the plugin if I am generating MPEG-1 layer 2 audio.
If I check the box to play the first clip automatically, the first clip plays with no audio whatsoever under almost every combination of video/audio options. The remaining clips all play audio without a problem.
The only way I have found to get audio to play during the first clip is to use TMPGEnc to generate a system (audio + video) stream as a .mpg file, with the audio set to MPEG-1 layer 2. In this case, the clip will properly automatically play with audio, ending with the menu. I have been able to mix clip types also, with the first autoplay clip as system stream with layer 2 audio, with the remaining clips being video only (.m2v) files with a .wav file added using "Replace Audio".
This raises the questions:
- Is there a good reason why the first clip audio would behave differently if "First clip as first play video" is checked?
- Is there any danger is mixing clip types on a single DVD, such as a .mpg system stream with MPEG 1 layer 2 audio in one clip and a .m2v video elementary stream combined with a .wav PCM audio elementary stream in another?
- As MPEG-1 layer 2 audio is not part of the DVD spec, but supported by many set-top players, if a DVD that mixes clip types as I described is played in such a player that will not accept this audio format, will the result merely be no audio in the clip or clips that use MPEG-1 layer 2 audio, with the disk otherwise playing correctly, or is the box more likely to just refuse to play the disk?
Any insight would be greatly appreciated.
Regards,
Eric J
Thanks for the information. I stumbled on this problem last Friday morning and have not had time to investigate. My first fear was that it was DirectX 9 related but that does not look to be the case.Originally Posted by Eric J
I can't think of any good reason for the audio on the play clip first to be any different from any other sections. I do not think there is any problem mixing the different formats.
I asked a similar question in the DVD player section. The general findings were that if the player worked with DVD-R/DVD+R, it would handle the MPEG audio. A point of distinction is that MPEG audio is part of the DVD spec, it just is not required to be implemented in a player.Originally Posted by Eric J
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
Unable to find "Play next clip" when authoring DVD
By zonag5 in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2010, 02:50 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
