I have a large file that is iso and was wondering how to convert it to make a vcd/svcd ... or anything that I can put on a reg cd....
Not sure if it is a nero or easy cd creater and not sure if that matters...
I tried using DVD2AVI but could not get the audio .....
any help would be appreciated...
thnx
Results 1 to 9 of 9
Try, if Daemontools can mount the iso or try isobuster to extract files.
thnx dragonsf I will try it ......... will it convert it to a form I can burn such as mpeg or convert with tmpgenc......??
thnx again
........>>>>I tried the isobuster and my result is as before --(I was prob not very clear to what I need) it resulted in two folders audio_ts and video_ts. The audio folder is empty and in the video_ts folder there are several files vob bup ect and I am unable to find a program or method to make them into mpeg to burn as a svcd or vcd.....
The files are in four or more parts and some are over 1 gig in size.... By just adding .mpg to the end I can watch it and it contains the audio but when I try to convert using any of my present tools ( dvd2avi, tmpgenc eovideo, vcdgear, virtual dub etc........ I can either not get it to work at all or can only get the video ........?? ...... no audio ...??
What I would like to find is either a one or two step method to take the iso and convert it to burn as a svcd....... As the file is larger than will fit on a regular cd I will need to cut .... etc...
thnx again for any Help -
With a mounted ISO thru Daemontools, you look at the iso, as if it were a CD.
If it's a SVCD, you can use tmpgenc with mpeg-tools and try to demux the avsegment (this is an avi).Not sure about VCD, but the .dat file should contain the mpeg-1 data as well. -
thnx for the info I tried the sperdvd and it seems to work fine ....... I was unable to find the daemontools listed on this site and after doing a web search I thinik it is not what what I am looking for ........
Name : daemontools Relocations: (not relocateable)
Version : 0.70 Vendor: (none)
Release : 3 Build Date: Fri 01 Jun 2001 09:57:51 AM CST
Group : Utilities/System Source RPM: daemontools-0.70-3.src.rpm
Size : 142664 License: See djb@pobox.com
Packager : Bruce Guenter <bruceg@em.ca>
URL : http://cr.yp.to/daemontools.html
Summary : A collection of tools for managing UNIX services
Description :
daemontools is a collection of tools for managing UNIX services.
supervise monitors a service. It starts the service and restarts the
service if it dies. Setting up a new service is easy: all supervise
needs is a directory with a run script that runs the service.
thnx again for your help -
What you need is this:
http://www.daemon-tools.com/
(Maybe that's too easy) -
An ISO is the ideal thing - it's meant to be put on a reg cd.
/Mats -
dvd ...not a vcd/scvd. If it is indeed an iso of a dvd lrspinelli could just
use isobuster to extract the files to his drive then follow one of the dvd
to vcd/svcd guides. He would be able to skip the first step ,ripping .
Good luck
Guido -
thnx all ............ Yes it is DVD iso which I am converting to svcd .......
Thnx for the great info mats.hog and guidoo and dragonsf for that link I tried and works great.........
This is my first experince with this .......
thnx for all the help .........!!!
I am using the super dvd ripper to convert the vob files into svcd ..........
convert video_ts to iso?
By piscian18 in forum Authoring (DVD)Replies: 7Last Post: 26th Jun 2010, 15:17 -
is there a way to convert iso to avi
By videodude1966 in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2010, 12:00 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
Convert to .ISO
By Jomapil in forum ComputerReplies: 3Last Post: 2nd May 2009, 18:02 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01
