im trying to convert these WMV files and TMPEG wont open them, but it will open this other WMV low quality file. the ones that wont open have a bitrate of 1986 kb/s each and the other that will open is 705 kb/s. i think its because of some new technology or something involving WMP like version 7.1 or something like that. anyone know what to do to make it work?
Windows Media Player and DirectX are now up to Version 9 and yes, some of the codecs have changed so that the latest encoded videos may not be backward compatible.
You will probably need to upgrade to WMP9 (or you can try just updating to the Version 9 codecs which are downloadable from the MS website).
But a warning - WMP9 may upset older applications so make sure you set a restore point first.
How to convert that like a High Quality WMV Video?
By iqbal88 in forum Video ConversionReplies: 1Last Post: 11th Mar 2012, 13:15 -
Converting my HD DV movies to play on TiVo HD in high quality
By nashmarkt in forum Newbie / General discussionsReplies: 24Last Post: 7th Sep 2010, 13:21 -
How To Produce High Quality WMV from AVI / DVD Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 21:13 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 17:08
