I encoded the movie described above using TMPGEnc. Then i tried to make a Svcd using CDRWIN 5.0 but the resulting movie was not even recognized as a svcd movie by my Pioneer DV-250 dvd player. Any ideas?
first, you must stretch the audio to 23.976 fps using goldwave or besweet. I have better results with besweet.
Then encode under the ntsc (film template). under the advanced tab, select do not frame rate convert. also use 3:2 pulldown when playback for the encode mode
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 11:46 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 11:33
