I have followed the steps to make a vcd and an svcd. When I make my vcd, and play it on my dvd player, everything is fine; no audio sync problems, nothing. but when i turn it to an svcd, and play it on my dvd, every second it skips, it's so slow, and the audio is all messed up. what am i doin wrong?
Your dvd player may not be SVCD compatible, you can check here:
https://www.videohelp.com/dvdplayers
You may also try the famous header trick expliation and guide here:
http://www.vcdeasy.org/modules.php?name=_Guides&id=VcdTrick
Also just from personal experience your dvd player may not play 44Hz audio with mpeg2 video, you may need to convert to 48Hz
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
