I'm trying to go from mini-dv to divx.
I have transferred the video to my hard drive via firewire in mini dv format (DV-AVI), not compressed.
I found out though that Vidomi divx encoder can NOT encode divx from mini dv format, why it can't I have no idea but it has caused me a major headache.
I got the huffyuv-2.1.1 codec because it is supposed to be loss-less and was suggested as a work around for just this problem. I also have AV_IO but I can't get it to capture any video from my mini dv player, even if I have the player running when I start the software as they recommend.
I guess I can't understand why it is so difficult to encode un-compressed avi into divx. I'd even spend money if there was a way to do it. Does anyone know if this is possible.
edit: I posted here becuase I don't know if there's another way to capture it that would let me encode into divx.
Virtualdub only recognizes type 2 DV files and requires a DV codec. You must therefore capture in a type 2 DV avi file with DVIO or DVapp (freewares). You must also install a DV codec (for example, the Panasonic DV codec). See the Tools section in order to download these.
How can i encode subtitle to avi file
By boo143 in forum SubtitleReplies: 0Last Post: 17th Jun 2008, 20:58 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29 -
all I want to do is encode an avi file
By moopsimoo in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 14:56 -
Best way to re-encode 13GB DV file to 4.5GB avi/mpeg/wmv
By ColKurtz in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2007, 21:59 -
Trying to encode DVD to DIVX/AVI or h264
By cassavetes in forum ffmpegX general discussionReplies: 11Last Post: 25th Jun 2007, 10:46
