if i have download a unfinished mpeg files and i want see some movie inside that , can i use mpeq corrector to fix and have a look or any software can see this thing.
and how can i put a still image to become moving movie ..?
The beauty of an MPEG file is that it allows you to watch it as you are downloading it or if you have an unfinished file. Windows Media Player can do it.
To your other question
"and how can i put a still image to become moving movie ..?"
There is a program called BMP2AVI that turns .bmp's into a avi movie. It also allows you to chose what codec you wish to use -
yes i wish mpeg would come out with an svcd looking file but somehow just a bit bigger than a normal vcd
, we can all dream anyways if this was an avi take a look at vcdhelp's software section and get divfix just an extra bit of info...
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
