i have just done ice age with dvd decrypter u must unselect the vobs and ifo files it gives u scoll up and u will see another set of vobs select the ifo file above hold ctrl button down and select the three vobs below only select these files to rip put in dvd2 one hey presto succsess this works only come across this prob with this movie
If you want other people to help you you should at least show some effort in explaining your problem.
Using a structure, breaks, full stops, comma's,... can do wonders in this case.
MrSnakeSony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8 -
MrSnake, I think he is giving a solution to a problem...although it is very hard to follow with out punctuation.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Ice in oklahoma....
By freebird73717 in forum Off topicReplies: 15Last Post: 24th Feb 2010, 10:03 -
Camcorder video of ice hockey - gap stitching
By p9g in forum EditingReplies: 2Last Post: 24th Oct 2008, 06:13 -
R.I.P. Stan Winston at age 62
By guns1inger in forum Off topicReplies: 3Last Post: 21st Jun 2008, 09:39 -
Ice Age 2
By mr_jbloggs in forum DVD RippingReplies: 4Last Post: 18th Oct 2007, 15:04
