I am capturing material from Digital Cable and would like to have the Surround Sound 5.1 audio that is in the content. I am using a Canopus ADVC-100. Is this possible? If so, please tell me how.
I would like to do this also. I have a Sound Blaster Audigy and have been searching for ways to capture the 5.1 AC3 stream from my digital cable box which I have connected to the Audigy, and havn't been able to find a way to do so...
I read an article about this, if your card is a Digital TV Tuner Card, you can capture to a file format which easly converts to vobs without ANY encoding.It can then be burnt to a dvd or converted to just about anything using DVD rippind methods (exept don't rip the DVD) I'l tell you when I found it
Surround Sound in Movies
By therock003 in forum AudioReplies: 36Last Post: 1st Jun 2012, 05:50 -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Lg ht 355sd surround sound
By byrnech in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Oct 2011, 05:08 -
Need Help Encoding: Surround Sound Goes Away
By antiwebbite in forum AudioReplies: 3Last Post: 9th Jun 2010, 18:48 -
Surround Sound Separate
By kwalitykontrol in forum AudioReplies: 1Last Post: 31st Mar 2008, 23:01
