Hi Folks...
I'm having terrible problems trying to get my v7700 card to capture video. I'm running a dualboot btw ME and 2000 and cannot connect to any capture drivers in either system. I've tried several things to the point where my machine starts giving me the dreaded blue screens and I'm loosing courage. Here's what I tried:
asus wdm driver
nvidia wdm driver (1.08, 1.19, 1.22)
"default" microsoft wdm driver
capturing in asus live: didn't work
capturing in asus DVCR: didn't work
capturing in VirtualDub: didn't work
Usually, the apps just doesn't find the driver or once in a while I'm able to capture a few seconds with a big white bar across. There's absolutely no continuity in my problems: At reboot one problem goes away and another pops up in it's place.
I know that many ppl have had these problems but I haven't found a solution yet....please help
kind regards,
Mike)
I was never able to get this card capturing in XP, but had more luck in 'win98 se. I used the standard asus capture driver (a vfw driver I think) with AVI_IO capture program. It would drop 1 frame in 10,000 and never suffered audio sync problems using the Asus2 codec quality 8-9.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
Well, let me simplify:
I'm running the Asus GeForce 2 GTS (v7700) on WinME. Which WDM capture driver should I try and where do I get it?
Thanks a lot,
Mike
WDTV or Asus O!Play ?
By lenti_75 in forum Media Center PC / MediaCentersReplies: 7Last Post: 5th Oct 2010, 22:49 -
Asus or Dell Laptop
By Poppa_Meth in forum ComputerReplies: 2Last Post: 1st Mar 2010, 21:11 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Shall it be mobo Asus or Gigabyte
By RabidDog in forum ComputerReplies: 13Last Post: 20th Sep 2007, 05:43 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 06:55
