I know how to make in SVCD from a DVD movie, but I downloaded a movie and I think it's an MPEG2 file. I can open it with DIVX. What I want to know is how do I go about burning this as an svcd?
this is a very confusing post... First, you talk about a DVD movie, then you're talking about an MPEG2 movie and then you're talking about a DivX movie.
Look, i think, if you can open it with a the DIVX player, you have got a DIVX movie... not a DVD movie, not an MPEG2 file. They're all different ways of coding the movie. If you DLL'ed it, it probably was an AVI file (uses mostly DIVX-codec).
Ok, so you want to make a SVCD (that is made from mpeg2 file). Now, to be able to do that, you need to convert the AVI/DIVX to an MPEG2 file.
I always use thise method
https://www.videohelp.com/forum/userguides/119210.php
(it is normal if that takes 10-12 hours)
Now, you need a program that can burn CD's... Use adaptec or nero. NEW COMPIL -> SUPER VIDEO CD ->select and drag the file ->BurnWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Ok, I can't open the video file with virtual dub because I get an error. The error says, Couldn't locate decompressor for format MP43 ( Microsoft High Speed MPEG -4 V3) virtual Dub needs a video for windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by windows media player , are not suitable.
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 07:47 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making Widgets
By redstripes in forum Off topicReplies: 2Last Post: 16th Jan 2008, 10:43 -
label making
By yuhr in forum MediaReplies: 4Last Post: 29th Nov 2007, 22:34 -
making dvd;s
By brenjim in forum Capturing and VCRReplies: 2Last Post: 14th Jul 2007, 11:48
