Has anyone experienced a heavy CPU load when using the ATI MMC capture program? I'm to capture a Laserdisc at DVD resolution MPEG2 @ 3000kbps and the task manager shows 100% CPU load during capture - I have a 1.7G P4 with 512MB or ram. I thought I would be at least able to capture at that bit rate - the capture is worthless as the frames dropped during capture were huge. I even tried this with a fresh install of XP with nothing else installed other than the ATI driver and the 7.6MMC app and had the same results.
Another interesting observation was that just the application running, i.e. not capturing, the CPU load hovers around 30%... is this normal? I realize that most capture uncompressed and post process, but HD space is currently at a premium (temporary) - three days to capture and postprocess a two hour movie is a bit hard to swallow (I want to capture/convert my Starwars Trilogy LD to DVD as the LD play has been flaky recently).
Thanks,
Ted
Try VirtualDub for capping... ATI stuff kind of blows...here are a few capping guides https://www.videohelp.com/capture
Doing it to Mpeg2 in the ATI software ain't gonna work. With the 128 pro, the only really acceptable capture results for stuff where picture quality matters are if you take it in UNCOMPRESSED in Virtualdub at 720x480 and then recompress with Tmpgenc or Mainconcept to a VBR multi-pass MPEG2.Originally Posted by tedkunich
Of course the uncompressed drop is gonna cost you 50 gigs per hour.
With your system you MIGHT be able to keep up in Vdub with the Huffy lossless codec. It will mean higher CPU usage and still might choke for you, so make sure you turn all background stuff off.-MPB/AZ -
Thanks,
Did just that - post process is such a bitch though... takes forever... SW episode 3 done, 4 & 5 yet to go....
Ted
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
