I've been using the Canopus ADVC-100 since Nov, and I've noticed that captured animation "flickers" or "shudders" whenever the camera pans across a scene.
Just recently, I've started using TMPGE Plus to make SVCDs of animation programs. I've discovered that those same "shudders" will turn into a more noticable "pulse" after using the noise reduction and high quality settings.
My question: Is this a tmpge problem or a canopus problem. Please help me!!!![]()
If the DV file looks ok when played, it could be tmpgenc is using the wrong field order setting, try swapping this. I capture using Ulead Video Studio PAL DV template, which has Field A set as 1st field, however when I load the DV file into tmpgenc & let the wizard take a look at it, it sets field B. The encoded output looks fine, so I just leave it set to B.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
Follow this guide for filters:
https://www.videohelp.com/dazzlecapture.htm
I make DVD’s from VHS source animations that look better than the original with this method. I also use best quality and 2 pass VBR. Use good cables to the ADVC-100
Hope this Helps
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 17:26 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
