  1. I've never had a problem with MMB, overburning or otherwise, until now.
    I've made couple DivX rips which are over 700MB and wanted to burn them with MMB. Here's my output:
    IOCompactDiscServices: LITE-ON LTR-24102B Rev: 5S54
    Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
    WARNING: Unit not ready, still trying...
    WARNING: Length of toc (84:16:00, 379200 blocks) exceeds capacity of CD-R (79:57:74, 359849 blocks).
    WARNING: Ignored because of option '--overburn'.
    WARNING: Some drives may fail to record this toc.
    Starting write resid: 68
    at speed 24...
    Pausing 10 seconds - hit CTRL-C to abort.
    Process can be aborted with QUIT signal (usually CTRL-\).
    WARNING: No super user permission to setup real time scheduling.
    resid: 104
    Turning BURN-Proof on
    Executing power calibration...
    Power calibration successful.
    Writing track 01 (mode MODE1/MODE1 )...
    ?: Undefined error: 0. : scsi sendcmd: no error
    CDB: 2A 00 00 05 A3 82 00 00 0D 00
    status: 0x2 (CHECK CONDITION)
    Sense Bytes: 70 00 03 00 00 00 00 0A 00 00 00 00 0C 00 00 00 00 00
    Sense Key: 0x3 Medium Error, Segment 0
    Sense Code: 0x0C Qual 0x00 (write error) Fru 0x0
    Sense flags: Blk 0 (not valid)
    resid: 26624
    cmd finished after 4.396s timeout 180s
    ERROR: Write data failed.
    ERROR: Writing failed - buffer under run?
    ERROR: Writing failed.
    The bin/cue I'm trying to burn is only 740MB but cdrdao says I'm trying to burn 850MB. So, when it gets to a little over 800MB, it errors out. The disc mounts (although I set it to eject in MMB) and I can see its contents in the Finder. But, when I try to view it with VLC, the drive just churns and VLC freezes. Ejected the disc and tried it with my combo, same result. Any ideas?
    BTW, my version of MMB is 0.4, don't know if that matters.
  2. Downloaded v0.5 and tried CDrecord. Got this:
    ./cdrecord -overburn -eject dev=IOCompactDiscServices /Volumes/Video/image.img
    Cdrecord 2.0 (powerpc-apple-macosx6.3) Copyright (C) 1995-2002 J�rg Schilling
    ./cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
    ./cdrecord: WARNING: This causes a high risk for buffer underruns.
    scsidev: 'IOCompactDiscServices'
    devname: 'IOCompactDiscServices'
    scsibus: -2 target: -2 lun: -2
    Using libscg version 'schily-0.7'
    ./cdrecord: Warning: using inofficial libscg transport code version (csapuntz-scsi-mac-iokit.c-1.4 '@(#)scsi-mac-iokit.c 1.4 02/10/19 Copyright 1997,2001 J. Schilling').
    Device type : Removable CD-ROM
    Version : 0
    Response Format: 2
    Capabilities :
    Vendor_info : 'LITE-ON '
    Identifikation : 'LTR-24102B '
    Revision : '5S54'
    Device seems to be: Generic mmc CD-RW.
    Using generic SCSI-3/mmc CD-R driver (mmc_cdr).
    Driver flags : MMC-3 SWABAUDIO BURNFREE
    Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
    ./cdrecord: WARNING: Data may not fit on current disk.
    ./cdrecord: Notice: Overburning active. Trying to write more than the official disk capacity.
    Starting to write CD/DVD at speed 24 in real TAO mode for single session.
    Last chance to quit, starting real write 0 seconds. Operation starts.
    Turning BURN-Free off
    ./cdrecord: Undefined error: 0. write_g1: scsi sendcmd: no error
    CDB: 2A 00 00 05 7D A0 00 00 10 00
    Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 63 00 00 00 00 00
    Sense Key: 0x5 Illegal Request, Segment 0
    Sense Code: 0x63 Qual 0x00 (end of user area encountered on this track) Fru 0x0
    resid: 32768
    cmd finished after 4.536s timeout 40s
    write track data: error after 736952320 bytes
    Sense Bytes: 70 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00
    MO, US
    It looks like you're burning it as ISO9660 data. When you burn as data you only get about 700MB of space (850MB image sounds about right for 740MB data).
  4. Hmmm, so what is another way to overburn a data/DivX disc?
  5. What do I need to do so that I can overburn a 740MB DivX to an 80 minute (700MB) CD? It has to be mode 2 in order to be overburned, right? I opened up the .cue generated from MMB in TextEdit and this is what it said:
    FILE image.bin
    BINARY
    TRACK 0
    MODE1/2048
    INDEX 01 00:00:00
    MO, US
    Well, you can overburn in mode1, but you're not going to be able to fit 740MB on a 700MB disc that way. I've heard of some technique for burning divx movies as mode2 (which means your file would fit without overburn), but I don't know anything about it because I don't bother with divx.
