hello all
i have a huge problem.
i use virtualdub to convert avi 23.976 to avi 25 frames.
when i try to convert some files ( for now only 2 of many that work)
i had some bad frame, and virtual dub show an error massage
and stop the convert. is there a way to fix that or to pass this problem ??
p.s when i play this avi with any divx player, the file is ok
i can see all the movie without any problem.
the problem happend when i try to convert the avi.
hope 2 find help in here
10x
Results 1 to 10 of 10
well first of all..why would you convert the framerate??
follow this: https://www.videohelp.com/forum/viewtopic.php?t=119210 -
as u know ( i hope)
svcd on stand alone cant play 23.976 frames only 25, or 27.976
so thats why !!!! -
you are very mis-informed my friendOriginally Posted by alakoma
my dvd standalone plays them fine. -
Mine too.
"Art is making something out of nothing and selling it." - Frank Zappa -
Mine doesn't play 23.976fps either...thats why I also convert all my NTSCfilm AVIs to PAL 25fps before encoding
Go to www.dvdrhelp.com/forum/userguides/142555.php. It is a guide to getting rid of bad frames in virtual dub. You will need a copy of v-dub mp3. The guide provides a link to obtain this version of v-dub.
If your framerate is 23.976fps, then you should use 3:2 pulldown when playback. You don't have to convert your 23.976fps files to 25fps.
3:2 pulldown when playback is used when you have a FILM source movie (23.976fps) to leave it at 23.976fps but have your decoder play it back at 29.976fps (works great for ripping DVDs). When 3:2 pulldown when playback is used it does this.. It takes four sequential video frames (A, B, C, D) from the FILM and are drawn on the video display as A1, A2, B1, B2, C1, C2, D1, D2, where the 1 or 2 represents the field number within the frame.
Hope That Helps!!!
:P
10x laddydaddy
the guide was very helpful, a small thing 2 do
i dot know why i didnt think about that
10x
Fix bad avi file
By TBoneit in forum Video ConversionReplies: 8Last Post: 4th Oct 2011, 11:17 -
The timing between movie and subtitle is bad. can I fix that?
By Codonauta in forum SubtitleReplies: 4Last Post: 28th Dec 2009, 13:39 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Fix for skipped frames?
By Tom in HD in forum MacReplies: 1Last Post: 15th Dec 2007, 17:44 -
Fix Bad Header/Bugs in an .avi divx file
By krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 07:54
